Home › Forums › General Discussion & Questions › 5v trigger from ??? › Reply To: 5v trigger from ???
28 January 2023 at 18:14
#43371
Hi roycke,
Welcome to Beoworld!
I suggest using a separate mains-derived trigger instead of the USB or HDMI signals, this way you have easy control of the trigger signal and there are no annoying pops and clicks through the audio when the trigger voltage changes (as it often does when using USB):-
Kind regards, Steve.
