April 18, 2022 at 1:45 am
#4267
Martin: Do you know what that preset time would be?
This time is not adjustable and is only a few seconds sufficient to close/open the drawer. The issue is that the motor should not be continuing to run. Since it is seeing 13v when closed, the OpAmps are active. Since the drawer does open and close, the signals from the two pins of 1C8 are working, but may not be resetting.
