April 17, 2022 at 7:39 pm
#4262
Thanks Martin. This then means you need to check how long those pins are active in each direction. If the go back low once the drawer closes then I would look at the OpAmp driver circuit to see if there is a bad cap for example that is keeping the output latched.
