Reply To: BeoLink Converter 1611 Innovative Configurations
Home Forums Product Discussion & Questions BeoLab BeoLink Converter 1611 Innovative Configurations Reply To: BeoLink Converter 1611 Innovative Configurations
#42540
ebnrob
    • UK
    • Topics Started 7
    • Total Posts 57
    Interesting thread!
    I have my BL3500 connected to a 1611 converter running as the audio master together with a BLGW. I made a din to RJ45 cable to connect the 1611 to a Core and wrote a couple of macros for the BLGW to turn the BL3500 on and set to N.MUSIC when the core starts playing and switch it off  after 30 seconds of no playback. Volume’s set to start at 60 on the 3500 and I use an essence wheel paired to the core for control + the B&O app. It all works really well, however it would be good if I could take the BLGW out of the equation and have the 3500 trigger on/off by itself. I did consider the Almando masterplay box but the cost was too much… 300 EUR vs. £30 for the 1611!
    The Almando requires the 3500 timer function to be On all the time for the 3500 to trigger on.. I wonder if this is just a voltage signal down the masterlink cable ?
