Reply To: BeoLink Converter 1611 Innovative Configurations
Home Forums Product Discussion & Questions BeoLab BeoLink Converter 1611 Innovative Configurations Reply To: BeoLink Converter 1611 Innovative Configurations
#42410
Guy
    • Warwickshire, UK
    • Topics Started 15
    • Total Posts 1,342
    Final (?) version of Test Schedule attached.
    I entered a few final notes (in blue) about my attempts to trigger BL3500 using 5v into the MCL socket.  I also made up a lead to test the PC input of the BL Active, only because I had never tried that before.  The PC input worked fine using pins 2, 4, and 7 for Left, Right and Gnd respectively.  I could select using ‘PC’ on Beo4 and it worked as a local source, but as soon as I disconnected the ML it stopped working – so there is no simple BL Active standalone option.
    I have finished testing setups for now, but am now on the lookout for a BL3500 PCB36 with SW 2.1 or later.
    • This reply was modified 2 weeks ago by Guy.
