Reply To: Siri Remote 2 mit Apple TV HD an Beovision 10
#4212
srm
    Hi Guy,
    thanks for answer.
    Unfortunately, it seems you’re right.
    I have the “old” Siri Remote without the white circle and it can control the BV directly.
    My new Siri Remote 2 (the aluminium one) can’t control- I think because the missing B&O IR Code.
    So far I haven’t a solution to fix it – probably there’s really no solution.
    Greets
    Sven
