Reply To: Beogram 4002 speed issues April 14, 2022 at 5:31 pm #4191 Mark-sfBeoworld Member Topics Started 0Total Posts 57 I know the muting board had the additional pattern so it could be the same for the main board. It is easy enough for you to check. In any case the newer sealed ones are your long term solution.
