April 14, 2022 at 1:34 am
#4172
Good evening,
Here are the answers to your questions:
“Is it possible to get the back aluminium panels of the Soundcenter as spares?”
Yes, from a B&O dealer.
Same with the “end caps” that you remove when you use B&O wall mount. Can they be sourced as spares?
Yes, as above BUT if you get the STB Bracket table stand, they are included with it.
Has anyone experience from the STBBracket table stand?
Yes, I have it and it is doing its job perfectly. It is not motorized, however, but you can rotate the TV manually to access the back panels.
Good luck,
Jean
