13 April 2022 at 08:42
#29840
Hi Mark,
Thank you for your answer!
I mounted everything back together (using the cardboard strip procedure), but the main spring still forces the dust cover to close, is that the normal behaviour? The 2 small lateral springs are not connected to the main dust cover but to the panel underneath :
Thank you in advance,
Best regards,
Audric
