Reply To: Problem programming Beo4 remote to IR repeater/blaster
Home Forums Product Discussion & Questions BeoRemote Problem programming Beo4 remote to IR repeater/blaster Reply To: Problem programming Beo4 remote to IR repeater/blaster
#41140
jmw74
    • Topics Started 0
    • Total Posts 1
    Hi @mojofml – may I ask where you found the “more expensive IR blaster that supported 455khz?” Ideally a Tuya compatible one
    I’m looking to add my B&O tv to my home automation – but can’t find a suitable IR blaster. Wondering if I can avoid building my own using a raspberry pi and some IR leds and LIRC!
    thanks
