Home › Forums › General Discussion & Questions › static/popping even when not playing › Reply To: static/popping even when not playing
1 December 2022 at 09:41
#41120
Sounds really sensitive problem. Maybe some grounding issue in cables, platter adjustment. I would check mechanically first, like Pepps above mentioned. Is the amp same series as the 1700 i.e. compatible. If it is generating static electricity when platter moves, maybe try to put your hand on metal part of player…any effect. You create discharge route with your body. But first I would open it up and check any physical issues.
