Home Forums Product Discussion & Questions BeoGram Beogram 8002 stops short Reply To: Beogram 8002 stops short
#39510
sonavor
    Have you performed the service manual adjustment for the forward and reverse scanning control buttons?
    Both should measure around 620 mV at their steady-state (not pressed) position.
    If those are adjusted correctly then perhaps you do have a problem with one of the position sensors.
    Those can be replaced if necessary.  I believe Martin has a replacement part at the Beoparts store.
    The source of the problem could still be elsewhere though.
    To see what is going on for sure you would need to attach some probe wires to measure what the various sensors are actually doing.
    -sonavor
