Home › Forums › Product Discussion & Questions › BeoMaster › 4500/5500 and two-way › Reply To: 4500/5500 and two-way
21 September 2022 at 08:59
#39121
Beocord and Beogram do not need any modification, they already work 2-way… they are just telling the master title number or track.
The master can send these data to the MCP and show them. The BM5500 is just compatible with the MCP, not BL7000 or BL5000.
The BM5500 has just a 16K Eprom, the later BM6500/7000 a 64K Eprom. So they are not compatible without modification.
There is/was a BM5500 BL7000 64K file available for an upgrade if modified with a BM6500 cpu.
If you don’t need timer programing: the BL1000 is much better than the Beo4 for the BM5500, easier and faster.
