Reply To: Beogram 4002 speed issues
#3895
Mark-sf
    The OEM relay is not available, but the replacement kits are readily on eBay depending on which relay you have. This is a DPDT relay that defaults to the 33 speed when unpowered. I would only jumper that side or remove it if you want to test 45 as well.  In any case, I would always replace it at this point as any cleaning fix is only temporary and the part is cheap enough.
