April 4, 2022 at 5:37 pm
#3887
The arm should be in the recording playing mode and then the weight should be adjusted to zero tracking force. Then you rotate the numeric dial without moving the weight so that zero is a 12 o’clock. At that point you rotate the entire weight to the desired tracking force.
