Home › Forums › Product Discussion & Questions › BeoSound › Theatre › New product launch – beosound theatre? › Reply To: New product launch – beosound theatre?
So I’ve played with my setup a little more today and the CEC controlling of Blu-ray player connnected directly to the Theatre is absolutely rubbish. In fact it doesn’t work at all.
1) when CEC is not disabled in the Theatre I cannot switch away to other sources once the Blu-ray player is turned on. E.g. when I try to watch live tv while the Blu-ray player is still powered on the tv attempts but is quickly pulled back to the Blu-ray player as a source.
2) when I disable CEC in the theatre I can freely change source to for instance live television.
3) at either approach 1) or 2) I can only control with my BeoRemote after I have started to control the Blu-ray player using the LG remote that came with my CX television. But still after a while of not controlling the Blu-ray player I loose the ability to control it with my BeoRemote one until I again first initiate the controlling with my LG remote.
Have any of you experienced this issue and if so is there a solution?
