Reply To: Beolab 8000 preventive care.
#3778
matador
    • Paris France
    Thank you for the comprehensive answer. Obviously note the one I was wishing the most!
    I’m good to open them and what I fear is the glue the seems to hold the front panels.
    I’ll do it as soon as I get or make new foam. In the meantime do you know if not using them will slow down the process (less heat) or as this nothing to do?
