Home Forums Product Discussion & Questions BeoSound Theatre New product launch – beosound theatre? Reply To: New product launch – beosound theatre?
#37400
NQVHNWI
FOUNDER Member
    There appears to be a multitude of holes in the VESA mounting plate to use. Once you select the holes and fasten, the cardboard template shows the precise location the base of the TV must be in relation to the VESA bracket.
    This leaves an overlap of 9.5mm between the two and the exact clearance for the TV not to contact the Theatre when all are combined together. There are then indications of some spacing keys to enable you to fined-tune the separation.
    That is how I interpret the video
