Reply To: Comibning BS-wirless speakers in a system with old Beolink speakers
Home Forums Product Discussion & Questions BeoSystem Comibning BS-wirless speakers in a system with old Beolink speakers Reply To: Comibning BS-wirless speakers in a system with old Beolink speakers
#37190
Millemissen
    • Flensborg————Danmark
    • Topics Started 23
    • Total Posts 1,064
    You will always need the NL/ML Converter…..it is the bridge between ML and NL.
    All ML devices will act collectively.
    Since you do not want any ML connected sources (i.e. a CD player) – you just have the needed ML driver in a setup like you want to create – you will only be able to listen to sources from a NL device on one (or more of the) BL 2000.
    Actually you don’t need the Essence (unless you want to connect speakers there).
