Home › Forums › Product Discussion & Questions › BeoMaster › BeoMaster 7000 to BS Core › Reply To: BeoMaster 7000 to BS Core
Trackbeo, so can I use this as Line Out to the core? All I want to do is select Line In on the Core and then control the Beomaster stack with the Beolink 7000.
I don’t own a Core, so not sure of which pin-to-pin cable… But solely regarding audio signals supplied and received, yes, that should work. Using the Beolink 7000 to drive the Beosystem as an (unknown type, non-integrated) “auxiliary source” will certainly work. But that’s what I meant about “remote control and proper Core integration” — using two remotes is fine but maybe someone with more experience has a B&O integrated solution? For example, my understanding is that the DataLink connector for Tape2 is capable of powering up the system — that’s how the “play” button on Tape1 or CD7000 fires up the main unit. But is there some way that the Core could trigger this? I dunno.
