Home Forums Product Discussion & Questions BeoMaster BeoMaster 7000 to BS Core Reply To: BeoMaster 7000 to BS Core
#35074
trackbeo
Blocked
    You can use that Line-In/Out port, but then the Beomaster will not play anything thru its own amplifier.  That existing clear plastic plug is a crossover, output-to-input.  (I used that jack to loop in an equalizer.)  I don’t know about selecting sources with the remote control and proper Core integration, but would use the output pins on the Tape2 connector to get a line-level output (which is always supplied).  That way no surprises when someone plugs passive speakers into the Beomaster and it “doesn’t work”!
