Home Forums Product Discussion & Questions BeoCord Looking for help Beocord 5000 Reply To: Looking for help Beocord 5000
#34151
Audric
Hi Mark,
Thank you for your answer!
I mounted everything back together (using the cardboard strip procedure), but the main spring still forces the dust cover to close, is that the normal behaviour? The 2 small lateral springs are not connected to the main dust cover but to the panel underneath :
20220413_093122
Thank you in advance,
Best regards,
Audric
