Home Forums Product Discussion & Questions BeoGram Arm balancing for Beogram 1800 type 5811 Reply To: Arm balancing for Beogram 1800 type 5811
#33830
Mark-sf
    The arm should be in the recording playing mode and then the weight should be adjusted to zero tracking force. Then you rotate the numeric dial without moving the weight so that zero is a 12 o’clock. At that point you rotate the entire weight to the desired tracking force.
