moxxey
FOUNDER Member
Interestingly, I find I’m using the Level more than any other device (apart from the Stage connected to the LG G1).
Granted, it’s not got the best sound across the range, nor the best-looking device, but it’s portable, easy to move around, just grab and go.
Only issue I find is the positioning of the controls next to the carry handle. They are sensitive and if your hand gets close it thinks you’re setting a preset or similar, if you move the Level when it’s playing.
