Reply To: BL3500 and the MCL/PL connector
#17648
Madskp
GOLD Member
    • Topics Started 2
    • Total Posts 196
    No 2. show the “:” in the display when connecting to power, but it does not respond to the command MENU,0,4,PLAY, nore MENU,0,0 PLAY ore MENU,0,9,PLAY on the remote control?
    It could be that it is the MKII version with the Powerlink connector. The MKI has MCL engraved in the metal under the DIN connector, where nothing is engraved on the MKII version.
    Try pressing MENU, MENU, 0, 4, PLAY and see if it helps? All these things require an extra menu press on the MKII version of the BL3500
