Reply To: After Recap Kit done, still a CD problem Beocenter 9000
#17624
Pindsen
    • Denmark
    • Topics Started 10
    • Total Posts 39
    Does the moving to the far upper happens every time the CD stops? If so I would assume it is okay since the voltage to the lense moving mechanisme might be shut off every time the CD does not succecfully starts up (recognize the CD). If you are sure about the correct polarity of C2103 then I would try the adjustment as Spassmaker suggest.
    /Pindsen
