March 17, 2023 at 9:15 pm
#17621
You shouldn’t run the full range signal from the amplifier into the tweeter terminals, unless the loudspeaker has built-in crossover filter for the tweeter. If it has separate connectors for the high and low register, that indicates the contrary. Then it’s probably designed for active filters and biamping.
