Reply To: Beocord 8000 BP534 transistor
#17617
Ninni
    • Topics Started 1
    • Total Posts 6
    Hi again, It turned out that the BC8000 did not have a “TR9” issue – my issue was also a little different. It could Play, REW and stop by command but when selecting FF it stayed in FF eventhough pushing Stop. Measuring around on board 4 showed correct electrical signals. It turned out that the FF solenoide was half stuck staying in outer position. Lubricating the rod inside solved the issue. Finally everything works 🙂 /Pindsen
    Similar to the issue I had with my Beocord 5000. Fixed by cleaning and lubricating.
    • This reply was modified 5 days ago by Ninni. Reason: formatting error
