Reply To: Beosound 9000 Mk3 connection wireless/wired
#17578
Millemissen
GOLD Member
    • Flensborg/Danmark
    • Topics Started 12
    • Total Posts 460
    Since you will only play CD’s from the 9000, you can use the digital output there (a coax to optical converter is needed)……means a (thin) cable is needed 😉
    Otherweise follow the instructions from Steve regarding the PL dummy plug.
    Volume will be regulated in the 28’s.
    Also…..your dealer should know about this.
