Reply To: Beocom 6000 MkII handset lost base connection
#17554
pegholme
    • Topics Started 1
    • Total Posts 4
    Guy
    Thanks – success in re-registering handset. But the base station database isnt accessible so my phonebook is empty on the re-registered handset. Also using the internal call system shows only ‘1’ or ‘2’ not the name I have given to each which is ‘landing’ and ‘kitchen’. If you have advice on accessing the phonebook I would be grateful otherwise I will need to enter them all on the re-registered handset which will be laborious to say the least! It might also lead to some conflict within the base station processing do you think? Thanks for advice on battery brand. I did cobble together my own from rechargeable AAAs at one stage!
