Reply To: BV6-26 – use of DVI Socket
#17523
Tignum
GOLD Member
    • Netherlands
    • Topics Started 1
    • Total Posts 179
    Hi, I do have a BC6-26(9280), and I do recall that I had to put the ‘HDCP mode’ setting to ‘hdmi’ or ‘disabled’, where ‘HDMI’ worked for my AppleTV
    The menu for that is found with Be04 when the ‘cursor’ is at the ‘settings’ position in the TV menu (don’t press GO yet), then press the red arrow button, then press GO.
    Go here (sorry it is in Dutch:-))
    20230315_180422
    Then press ‘red arrow’, and then ‘GO’
    20230315_180435
    20230315_180446
    20230315_180453
    I am not 100% sure if this is useful, as I understood that not all BV26’s have the ‘hd ready’ kit. But worth a try maybe?
    Good luck, Johan
