Reply To: How to connect a Beolab 3500 to BM7000
#17323
Guy
    • Warwickshire, UK
    • Topics Started 12
    • Total Posts 720
    I checked for continity on all pins.
    Maybe check for continuity between pin 1 and 6 – these are next to each other. These carry the left channel and AAL data respectively, hence if they are touching (inside the solder side of the din plug) it would possibly give some of the symptoms that you have described earlier (eg lack of data and left channel).
    (Picture is viewing pins – looking into plug)
    Screenshot (148)
    • This reply was modified 1 week, 4 days ago by Guy.
