March 10, 2023 at 5:51 pm
#17247
I understand, my thoughts exactly.
As there is a part number for each side, and a separate for the tip so they must come off? Perhaps removal destroys the old tip and once on, the new tip cannot be easily removed?
Do you know if a safe solvent may be used prior to new oil? if so what type?
Also there is a felt pad inside, does it have a “oil free” status? If so this gets more complex.
