Reply To: BeoLink Converter 1611 Innovative Configurations
#17244
Madskp
GOLD Member
    • Topics Started 3
    • Total Posts 216
    So I just tried adding the MCL2AV (and IR sensor) and it didn’t work – I tried several option settings on both TV and MCL2AV. But looking at the MCL2AV circuit diagram, pins 1 and 4 are only an output hence effectively I have two audio outputs connected, which cannot work. TV source for this and earlier test was the TV’s internal tuner (which worked over ML before with the BL3500). Regardless of the lack of audio, the BL1615/MCL2AV setup will not even pass control commands to the TV to turn it on etc. So this looks like a non-option!
    which commands did you use? With the 1611+MCL2AV combination it was the AV+Video source command or shift+radio+1 that made the sound from the tv come to the MCL2AV
