Reply To: removing control panel on beocord 8000
#17205
kingside
    • Topics Started 1
    • Total Posts 3
    thank you so much…I was using the screwdriver tip to press the clip towards the floor, with the whole unit on its back, i.e. with the edge you are talking about pointing straight up.  In that position when I insert the flat blade screwdriver into the slot, and press towards the floor, I am not pulling up on the switch panel , but pushing down towards the glass panel thinking that was the way to unlock.
    You are saying however that the clip is preventing an upward motion and that is what needs to be released while applying a gentile upward pressure.
    You have given me enough to go on.
    Thanks and  regards,
    Jay
