March 8, 2023 at 1:55 pm
#17134
If you use a powerlink socket on for instance a BS3 you will notice that 2 channels will give sound on the BL7-4 on the used socket.
(BS3 = Beosystem 3?)
This depends on the set-up of the channels in the BS3.
PL connect every BL7.4 with one PL cable. Setup one PL socked (= one BL7.4) to reproduce 1 channel (f.e. Surround Left), et voila.
But on a Beosound you can’t choose, so you’re right then one will hear both channnels.
