Reply To: Beosound 8 no longer connecting to wifi
#17100
Millemissen
GOLD Member
    • Flensborg/Danmark
    • Topics Started 12
    • Total Posts 438
    When I had my A8, it was running on wifi – so that should not be a problem.
    The problem is your new router/the settings.
    Hard to say anything, when one does not know the brand, the settings, the strenghts of the signal.
    After resetting it, I would try connecting it with a cable – that some times helps and can give you access to the menu for the wifi password.
    Use the Bang & Olufsen app to set it up.
