Reply To: BS theatre, to much bass
#17043
Steve at Sounds Heavenly
    • Topics Started 28
    • Total Posts 218
    Hi Zwaan,
    Welcome to Beoworld!
    First, I suggest you turn off Loudness in the B&O app, then either set bass to -1 and treble to 0, or set bass to 0 and treble to +1. This should give a good sound balance with the Theatre for most setups, then tweak the sound from there to suit your ears and preference.
    Kind regards, Steve.
