Reply To: First start of a BM6000 “not Working”
#16925
spassmaker
    • Topics Started 4
    • Total Posts 76
    Hi
    When you try to set the idle current measure the voltage at the speaker outlet
    (speaker switched ON 😉  ) or L201 on power amp board.
    Look for DC voltage more than 0.1 Volt.
    Often had this issue, look if you get any variations when you try to adjust the OFFSET Voltage with R210. If not adjustable check TR201 to 205, best to desolder them because some of them are connected in paralel.
    Seems that when you are through with this BM 6000 you can call yourself
    CEFBM 6000 (certified expert for Beomaster 6000 issues ;-))
    Regards
    Christian
