Reply To: Beocenter 7007 turntable speed doesn’t stay on 33rpm
#16887
Mark-sf
    • Topics Started 0
    • Total Posts 185
    As I responded to Colin, the control of 45 starts with the disc indicator switch. If that is not opening and closing properly you will get this symptom. Only after checking this should you check for the correct voltages around TR1 and 2. There are no likely cap issues in that circuit.
