Reply To: BeoMaster 5 and A.AUX
#16875
tb59427
    • Topics Started 3
    • Total Posts 9
    ….just do a search for it. And…..if you want to connect more than one device, you’d need some kind of switch too.
    As for the 2nd question – I remember back in the days, that I had a stock external USB drive connected….so yes that should work! I would however, not recommend it – it will be much easier to use a PC/Mac for this, because you will have to tag the files properly in order to have these searchable and showing coverpics etc on the BS5. MM
    Thanks for both hints. Found my old USB CD drive and hooked to the Mac. Still works 🙂 So that should be easier. Agreed.
