Reply To: BeoMaster 5 and A.AUX
#16870
Millemissen
GOLD Member
    • Flensborg/Danmark
    • Topics Started 12
    • Total Posts 438
    Right!
    However, the easiest way would be to use one of these:
    F1AEACB3-1DC3-404D-8E82-BDDB6A664144
    Please notice that Steve is only shipping to the UK for time being – but the Behringer can be bought elsewhere….just do a search for it.
    And…..if you want to connect more than one device, you’d need some kind of switch too.
    As for the 2nd question – I remember back in the days, that I had a stock external USB drive connected….so yes that should work!
    I would however, not recommend it – it will be much easier to use a PC/Mac for this, because you will have to tag the files properly in order to have these searchable and showing coverpics etc on the BS5.
