Reply To: BeoGram 1203 auto arm
#16852
Mark-sf
    • Topics Started 0
    • Total Posts 185
    Since both the at rest position and set-down are skewed it sounds like the arm had been moved too far right and there is a threaded pin under the counter weight that secures the arm to its post if I remember. Never saw many of these but that was how the 3000 did it. You need to remove the dustcover and adjust it from the rear.
