Reply To: Securing glass panels – Beocenter 9300
#16797
Tignum
GOLD Member
    • Netherlands
    • Topics Started 1
    • Total Posts 163
    Hi stotty, I used 3M 4910F, VHB™ Clear Foam Tape, 6mm x 33m, (about 1mm) Thick that you could consider to use. It has good bonding indeed, but feels a bit less permanent than glues. I used it on a BeoMaster 4500. In the old forums there are some more threads on this: https://archivedforum2.beoworld.org/forums/p/43948/319119.aspx#319119. Be careful with the thickness
    I used methylated spirit that dissolved the original tape but left the paint on.
    Best of luck. Johan
