Reply To: Beogram 1700 – how to remove platter?
#16771
Tjorven
    • Sweden
    • Topics Started 1
    • Total Posts 10
    I see, thanks. It’s stuck. Tried to pry the platter from the spindel by inserting two plastic knifes under the platter edge, but then it sounded as if the suspension springs where about to break, and the platter did not move at all. Could maybe soak the spindle in WD-40 and hope for the best.
