Reply To: Securing glass panels – Beocenter 9300
#16752
Foxtrott
FOUNDER Member
    • Topics Started 1
    • Total Posts 46
    Hi Tony
    When the glass panels on my BC9500 came loose afew years ago, I used a black coloured glue to reattach the parts to the panel. It was glue suitable for glass surface, but I don’t remember where I got it.
    The process of removing the residues of the old tape from the plastic frame parts was a bit of pain in the **** but worth the effort. Just be very very very carefull when cleaning the backside of the glass panel as the black coating/paint used comes off very easy when you touch is with anything harder than a feather or cotton wool and the circuits parts for the touch areas should not be touched in any way.
    As for belts for any kind of B&O equipment, I would always recommend “Beoparts” and you can find the belts for the BC9300 in the shop: Link to Beoparts Shop
    Cheers
    Foxtrott
