February 27, 2023 at 12:37 pm
#16750
I have fixed the glass panels on two BC9500s using super glue gel, with no problems after approx 10 years. Edit: I meant to add that I didn’t remove the old tape; just applied the gel over the top.
And you can get the new belts etc from Beoparts. https://www.beoparts-shop.com/product-category/beocenter/beocenter-9300/
This reply was modified 1 month ago by
Guy.
