Reply To: Beogram 8002 dead after adjustment
#16728
Mark-sf
    • Topics Started 0
    • Total Posts 185
    The Lift Circuit (IC1/TR9 is supposed to trigger the brake (TR32) so I would start there. Since you have a second 8002 you have a unit to compare. As to the change in arm speed once it gets over the platter, I do not recall that it does this normally as there is no reason it needs to. I know it doesn’t slow down on the 4xxx Beograms.
