Reply To: BeoLink Converter 1611 Innovative Configurations
#16635
Madskp
GOLD Member
    • Topics Started 2
    • Total Posts 196
    When going through the diagrams for the MCL2AV in the servicemanual i noticed some jumpers J4 (opt. TV) and J1 (opt. 5/6). Can’t find J2 and 3 right now.
    Skærmbillede 2023-02-25 kl. 16.25.16
    There are 2 more jumpers (2 and 3) and all of the located with the chips under the metal casing
    Skærmbillede 2023-02-25 kl. 16.10.11
    I know for sure the J1 is cut on mine, and If I remember correctly J3 is mounted, but not J2. Not sure if we can use it for something, but I will check up on the exact ones in use on my MCL2AV.
