Reply To: Flash Your B&O – new(er) thread!
#16386
Tignum
GOLD Member
    • Netherlands
    • Topics Started 1
    • Total Posts 163
    Hi Madskp, thanks! The symbols come from all kind of pdf manuals etc. (Maybe it would be nice to make a decent/scaled properly Powerpoint/Keynote template with all B&O devices?)
    I use the second BLC to separate the PHONO input of the BM6500 from the N.RADIO source of the Core (same Beo4 command). So the BLC is actually a filter for the CD command. Would you believe that it could be done without? I really want to keep remote commands logical for my dear family members and use RADIO for N.RADIO also. I agree, pretty elaborate, but it works well.
    Will change my diagram to Audio Aux Link 🙂
    Regards, Johan
